Wouldn't it be 13.22 amps / 8 = 1.65 amps per led so more like 4,000 lumens?
The LED's are wired in series, not parallel. And since current is everywhere the same in a series circuit......the SST-90 emitters, connected together in series and glued to the
massive heatsink for the modamag 4" Turbo Head:
Hi,
First, I want to tell you : GREAT JOB for your flashlight !
I want to creat a frontale light for fishing the night and I saw your wonderful light !
I have some question :
- I thingh use a emitter LED long time will heat the light very quickly ? --> How many time can you touch your light when it is cold.(to put on head if it's possible...)
- how many times can you use your light in continue with your batterie ?
- you must stop flashlight a long time after use because aluminium must be too hot (I think). So, how many time you must stop to refresh flashlight ?
Many Thanks,
Stéphan
Hello Stephan,
thank you for nice words- nice to see, that you are impressed by the pics.. but sorry, this light is may way too bright from my view for fishing or anything else to point at anything living- it has just been made to be bright-nothing else & no serious use for nothing..
thanks & best regards,
Steffen.
There is no reason to quote in it's entirety the opening post, quote deleted - Norm
...has anyone an idea, where the Luminous SST-90 GP-binning emitter is available?
Thanks,
Steffen
Does this bin exist at all?!?
I can't find it in the specs: http://www.luminus.com/products/Luminus_SST90_BinningLabeling.pdf
(Via http://www.luminus.com/products/white.html)
Otherwise, have you tried http://www.mouser.com/Luminus-Devic...ers/High-Power-LEDs-White/_/N-8usfj?P=1yzu5p9 ?
(Via http://www.mouser.com/Optoelectronics/LED-Lighting/LED-Emitters/High-Power-LEDs-White/_/N-8usfj/)
Good luck!
Hi Steffen,
the problem is that only very few bins will actually make it to the consumer market level and will be sold as retail.
The vast majority of bins will only be sold in huge quantities to enterprises and MAYBE to some wholesalers.
LarsB
