Any idea on the run time for the low mode on E12?
I just purchased an E12. On what I'm assuming to be a fully recharged HR-3UTGA (1,900 min mAh) Eneloop, I get just under 3 hrs of runtime on the medium mode. IIRC, I purchased my Eneloops from Amazon no more than 3 years ago and have recharged it fewer than 10 times. Before the test, I had drained it along with another Eneloop from the batch, to the point that neither could power up the E12 on the low mode, before popping the pair into the Sanyo charger that came with the batteries.
Is this runtime reasonable given the capacity and age of the battery or is it possible that the medium mode on my sample is higher than the spec 50 lumens? The medium does seem bright; the difference between it and the high mode, though noticeable, it's not as dramatic as I've seen in review videos.
Thanks.
You did a great job including important information! After re-reading, it sounds like these are two over-discharged, 3-year-old, 'sleepy' batteries put into a pair charger; if that's the case, then neither battery will be performing at peak capacity, I don't think.
I'd bet your E12 is working fine!
Thanks for the reply, Grijon. I believe I might now have not just two but four 3-year-old, over-discharged batteries then. I always thought completely draining NiMH batteries before recharging them was the proper procedure. Yikes. I've been doing the same with my electric toothbrush. Well, live and learn.
:welcome: Welcome to the forums, scs.
Does anyone know if the E12 has a low battery warning?
Don't own one, but I highly doubt it. I usually just compare the two highest modes (excluding Li-ions). When it gets hard to tell the difference, the battery is low .
Fenix specs 8 lms for 22 hrs....
i just looked it up and it says 8 lumens for 40 hrs?? i checked fenixtactical and outfitters. both say the same. maybe its typo on their end?
