Henk_Lu
On sunday I used my L2D, suddenly when I wanted to switch it on, the surface of the rubber wasn't flat anymore, but the switch bumped against the rubber and the whole thing was quite round. :confused:
I switched it on, it worked, off again, round rubber again. Then I screwed the tailcap off, the rubber flattened, I screwed it back on and it stayed flat. Half a dozen on/off and everything worked as it should.
What happened inside? Did something break so that this will happen again and eventually cause the switch to fail or is it "normal behaviour that happens sometimes"?
I haven't dissassembled the tailcap yet to have a look inside. The light is only a few months old.
Greets,
Henk
Greets,
Henk
