Green Lantern
- Joined
- Dec 13, 2007
- Messages
- 69
Edit-- (title should read P1-CE, not P1D-CE)
My son and I are first time owners of Fenix flashlights and wanted to write this review to let others know what our impressions are so far. I have owned the Fenix P3D Premium Q5 for about a week and my son has owned the Fenix P1-CE for about two weeks. They are both, by far the most powerful flashlights either of us have ever owned. Although my 14-year-old son does not have any complaints about his P1-CE, I have a few regarding the P3D.
First of all, I personally find most of the non-turbo modes on the P3D, except the highest general mode, disappointing. As a cyclist, commuting home after dark, I would not want to rely on anything but turbo or high, to make it safely home. And I certainly would not want to ever rely on the lowest output mode, which is a measly 9 lumens. If I wanted to use a 9 lumen flashlight I could have blown off the fenix and kept using my old mini mag light. The same goes for the S.O.S. mode. It's just pointless for us urban commuters and means you have to push the button a few extra times to get to where you want to be.
Secondly, the P3D allegedly throws off 215 lumens in turbo mode. That claim seems over-optimistic. To me the turbo mode of the P3D appears to be virtually indistinguishable from the brightness, throw, and intensity of the Fenix P1-CE, which is stated to be 90 lumens. Check out the photos below and tell me what you think. Also as a side note, I went on a night walk with my father last night and we compared my P3D to his 100 lumen Inova T3, and again they were substantially similar. I have posted some photos of these comparisons as well. Tell me if you agree or disagree.
Finally, my last gripe is about the limited length of time the P3D will perform on turbo mode and high mode. I have tried two different rechargeable batteries, both purchased from dealextreme.com. One was a set of 1000mAh dark green, 17335, generic, rechargeable cr123a batteries, and the other was Soshine 650 mAh cr123a rechargeable batteries. The P3D will run on turbo or high for about 10-15 minutes before it starts to intensely flicker. The beam will stay turbo bright or high, and retain a good throw (despite the intense flickering) for about another 10 minutes, and then it peters out to something MUCH less than the P1-CE. I'm just guessing but I bet it fades to about the lowest setting with is a 9 lumen output. The Soshines also performed really poorly in the P1-CE.
I'd also like to mention some positive aspects of the flashlight. When I used some non rechareable, 3 volt, lithium, Ultralast batteries, the P3D lasted on turbo for 67 minutes, which is enough time to get me home on my evening bicycle commute. But who wants to use non rechargeable batteries every night? Also the beam on the P3D, when set on high or turbo mode, really is awesome. And on strobe mode it puts out enough eye piercing lumens to get any driver's attention. Along those same lines the P1-CE also casts an awesome beam. As stated previously, the beam is almost indistinguishable from the P3D, and it completely holds its own with the P3D at about half its size and about half its weight. Check out the one photograph showing that the P1-CE is about equal to the size of my son's thumb, and (if desired) could fit on a key chain perfectly.
We bought our rechargeable cr123a batteries and an UltraFire charger from DealExtreme.com. I should let you know that one set we bought, some dark green, 350 mAh generic, 17340, rechargeable cr123a batteries would NOT fit into the P3D, but did fit fine into the P1-CE. Also, the UltraFire battery recharger, although useful and good for the price, seems very low quality. The switch that changes the charging output from 3v to 3.6v is jammed and seems to be potentially stuck on the 3v setting. Although you can physically move the switch I am not sure if it has any affect on the charger settings.
Now please check out the photos and let me know if you have any solutions for me to keep the P3D running for maximum time on maximum lumens on rechargeable batteries. Thanks!
