kerneldrop
What are the best way(s) to fill ~3.5mm space between the battery's negative side and the tailcap spring? (Other than soldering and welding)
adding 1 penny to the negative side makes a reliable connection. 2 is probably better, but 1 reliably works.
The Acebeam IMR 18350 1100mAh that came with the light might already be a higher discharge battery. I can't find discharge details on the battery. I want to see if I can draw more amps or get a brighter output using a higher discharge 18350 battery. The higher discharge battery is quite a bit shorter
The Efest INR 18350 is ~35.95mm
The Acebeam IMR 18350 is ~39.72mm
