Sold/Expired Finally, Piglet boards for sale
goldserve
Toronto, Canada
I will kill myself for putting this up for sale cause the labour on these is much more than 3 x flupic!
Anyways, I have the following board sizes available for $25 each. Custom programming is $10 extra.
1. 0.55" (13.97mm) - 0.063" (1.6mm) thick
2. 0.55" (13.97mm) - 0.024" (0.6mm) thick
3. 0.66" (16.87mm) - 0.063" (1.6mm) thick
Total thickness of board is 0.239" (6.07mm) for 1.6mm thick boards including the battery contact nub and subtract 1mm accordingly for 0.6mm thick boards.
The default UI is supposed to be a simple one and it consists of two fully buck/boost regulated levels only.
For low, I prefer 50ma
For high, I have 400ma, 500ma, 750ma*, and 850ma*
for *, use only li-ion ONLY
The UI:
1. LOW - HIGH - LOW - HIGH - LOW - HIGH - OFF - SET_UI
2. HIGH - LOW - HIGH - LOW - HIGH - LOW - OFF - SET_UI
3. (LOW) - (HIGH) - STROBE - BEACON - OFF - OFF - SET_UI
4. LOW - HIGH - STROBE - BEACON - OFF - SET_UI
5. STROBE - HIGH - LOW - SOS - OFF - SET_STROBE - SET_UI
Thanks Chimo!
my.php
Please order and state your toppings: board size, with or without battery contact nub, current setting for high level.
Also, please add $3 for shipping and 3% for PP Credit Card.
EDIT:
Here are some projects by me and some other members of the forum that use the piglet boards. Just to spark some creativity =D
TnC 27mm 18650 Light Build
Piglet/Cree-XRE Modded Arc-LS (chimo)
Aleph Light Engine Build
McLux PD/Clicky Light Engines
CR2-ION McR-17XR Reflector and Piglet Mod
Jil 1.3W Custom Piglet Holder Mod
Quick change 27-LT Piglet driver
CR2-ION Mod - Part 2
:party:
EDIT: Got these from the same batch at Chimo. Running great till now... Check it out here.
All I have to say is that people better snap these up before Kevin changes his mind. (sorry Kevin). :grin2:
I have one of these I set the drive levels at 60/400/460 (early release :)) in an ArcLS with a custom heatsink, Cree XR-E, Q3 reflector. Note that the UI is different in the model I have. It's a great combo!
Since I already had a file in Visio it only took a couple of minutes to mod it to the new UI. Here you go:
Paul
PP sent for 1 Piglet, style number 3.
PM sent with question.
What would happen if a regular AA battery was used with one of the high-current (750, 850mA) boards in high mode?
First of all, minimum input voltage should be around 2.4V so 1 AA battery wouldn't work too well. If you put a primary at around 3V and try to boost it to 850ma, it will sag and the converter will be out of regulation and all you'd get is around 600ma. You can try with 3 1.5Vs to get 4.5V.
I'll take 2 -
#1 Piglet board
#3 UI
400 ma, w/ battery contact.
PM sent. PayPal sent.
Thanks
I see the min Vin is 2.4 and max is 5.5 so that makes it a buck boost regulator.
do you have more info on this board, ie what is the boost voltage (for serial attached leds) etc.
Better put me down for one.
Size #1 (for aleph LE)
with battery nub
500ma
:paypal:
schiesz
:goodjob: I would like
2 x No2 ... 0.6mm thick, 13.97mm dia', with battery nub, and 850ma on high.
PM on its way.
Thanks,
Colin.
:oops: Your PM box is full.
Please let me know your PP ID, and if shipping to the UK is the same cost.
Thanks again,
Colin.
