Over the weekend my ARES group provided support for an annual event called the Power Climb hosted by the American Lung Association. For those of you unfamiliar with this type of event I'll give a brief explanation. The organizers typically find the tallest building they can (44 stories in my case) and make a contest out of who can get to the top quickest, using the stairs. Everyone has an RFID tag attached to their shoe and they are started at 15 second intervals. Pass on the right.
What does this have to do with flashlights? Very little actually, but the event draws some groups of people. One of those groups are firefighters. They do the run in full gear: full tanks, suits, etc. Everything. It's amazingly impressive. I have always had a lot of respect for firefighters but watching them do this for the last few years is truly awe inspiring.
Anyway, back to flashlights.
Watching the firefighters run past, I noticed a few things about their gear. Since they were from all around the state of Iowa, they were mostly in groups and each group had different types of gear. Some had metal (steel?) tanks, some had what appeared to be fiberglass composite, some had what looked like carbon composite tanks. Most had flashlights mounted to their helmets, and all that had helmet lights had the exact same host. It was a rectangular neon yellow body (unknown material) with a tail pushbutton switch.
I started thinking about the conditions this light is exposed too. It's exposed to extremely high temperatures, a decent amount of vibration, it's mount is such that it wouldn't surprise me if it gets beat quite a bit just ramming into things. It has to cut through all manner of smoke and provide a great deal of illumination.
I couldn't get a good look at most of them, but I did have 1 fireman stop on my floor and I was able to look at it a bit more closely. I was startled to see that his was LED! I can't be sure about the primary bulb, but it had a ring of what appeared to be 3mm led's (6 or 8) built into the reflector like a SF A2 or Streamlight Twin-Task.
So what are these lights? I googled for a few different terms but mostly I saw various led light bars that would go around the helmet, I did see 1 picture with one of these lights in it, but it wasn't they product they were discussing so it was ignored.
What kind of batteries do they use to stand up to the thermal extremes? It almost looks like the host could be a 4xAA in 2x2 configuration.
Any insight?
Any insight?
