KevinL
I just got my Terralux in the mail and I threw it on a 6 year old (Edit:) AA MiniMag that's seen better days.
The Terralux comes with a replacement reflector in a nice case that protects it during transport. I would have to say as packaging goes, they do a very good job. Installation is a snap, even for the most technically disinclined. If you can change the Mag bulb, you can load up the Terralux, which drops into the two holes on top.
On almost-fresh Duracells, compared to the Mag stock incandescent lamp that blackens just after a couple of hours of use, there is utterly no contest. The Terralux wins no matter how you frame it, in terms of beam quality, the amount of light, and the fact that the beam actually looks closer to white than burnt orange.
I've done some comparing, and out of the three Luxeons I've had so far, this one seems the greenest. The Q4H I got from the Shoppe is closer to white with a slightly green corona but unnoticeable unless you look at the edges of the light. The Terralux has an even green color throughout the beam. But far and away the whitest is the E1e+KL1 - it keeps reminding me of how we have been spoiled by Surefire lights and why we pay the price premium for the engineering, the beam quality, the whiteness of the Luxeon, and everything that goes with it. It's not a fair comparison but these are the LED lights I have /ubbthreads/images/graemlins/tongue.gif
Overall, I still like the Terralux for what it does and does well. It's not meant to turn your Mag into a L4 LumaMax or even KL1 overnight. It's a side emitter, compared to the other two which are Lambertian high dome LEDs. SEs really live up to their name, the beam spills evenly out to the side. Minimal focusing is required, just twist slightly to turn it on and it's already more or less in focus.
What the Terralux is good at is being a candle. Sometimes, you need an area light, and once you take the reflector off, candle mode looks really good. I bought it primarily because I needed an AA-powered light, and a long-runtime light, so the candle mode is an unexpected bonus. This is what the SE Luxeons are useful for.
I haven't had time to perform runtime tests, but I've measured current with the DMM and I'm looking at 310-320mA on alkaline cells. Since I don't feel like burning alkalines, I'll be doing the tests with 1800mAh NiMHs. Hope the Terralux doesn't overheat. I've popped the NiMHs in and there is virtually no difference from the Duracells. With the normal Mag bulb you'd already see a dimmer light due to the voltage, but not with the regulated Terralux. At a nominal 300mA drain, I should probably be looking at around six hours of runtime which is pretty decent.
Lastly, I've tried looking at the beam with and without the plastic window in place trying to determine whether I want a Borofloat lens by flashlightlens.com, and I'm not sure I can tell that much of a difference in light output. What I did notice, of course, was the lack of scratches and swirl marks. I may just buy the lens anyway since the existing one is scratched. What do you all think?
Pictures and more updates coming soon, if there is a need.
