KevinL
Where I come from we have a saying...thou shalt avoid being bitten by the same snake twice.
The snake, in this case, is unprotected lithium ions.
Those of you who remember The Incident took great pains to point out to me that it was the fault of the charger and not of the cells. This time, I'm doing things a little different.
Precautions: use of a pro-grade Maha C777Plus2 charger designed specifically for lithium ions. Using one cell at a time ONLY, a single 18650 in a SF U2. Charging only one cell at a time. Disposing of overdischarged cells immediately, although it has been communicated to me that the U2 shuts down at 3.15V and thus should not dangerously-discharge the cells. Halon 1301 10kg extinguisher beside the test bench. ("Nothing works as good as Halon") Kevlar helmet rated to stop NATO 5.56x51mm ball rounds should The Incident happen again.
Am I missing anything? Or should I go with Pilas instead?
Edit: I just chopped up a Dell Latitude LM P133's battery pack and salvaged 3 x 18650s out of it. I think they're 1300mAH units - not bad for a 8 year old laptop. It had 9 cells, 6 of which were corroded beyond all hope and discharged to around 0.1V, but 3 of them are 2.5V and 3.5 flash amps - salvageable!
It's kinda sad to chop up the pack, especially since this laptop means a lot to me, but the pack has been dead for around 3 years already, and I guess it's better that the pack donates its cells to science and lets them live on in a cutting edge light of tomorrow /ubbthreads/images/graemlins/smile.gif
Gonna get my C777 soon..
(Update: Got it. scroll down for first impressions.)
