eebowler
Ok. This is something I believe in but am a bit uninformed about the hows and whys involved.
( You don't really need to read this paragraph.) I bought a ZTS tester a while ago and gave it away to someone simply because it didn't give me all the information I thought it would. I had some old AA and AAA rechargeable cells which wouldn't be charged by two of three different chargers. Besides the usual very high self discharge rate and low % of actual capacity, the AAA cells didn't work in a regulated headlamp of mine and the AA cells simply couldn't dish out enough current to run some (most) lights properly. In all cases, flash amp tests performed on these cells gave unusually low readings even when fresh off the charger. The ZTS tester however, still said that these cells had 100% capacity when tested... :shakehead My belief in the flash amp test was set in stone.
My ROP/1274/1164 light is run by 6 Titanium high discharge cells which are proclaimed to be able to handle a 10C discharge rate. Silverfox proved this to be true in his NiMH battery shootout tests. The cells were obtained early this year and have been cycled (completely discharged) no more than 15 times and recharged about the same number of times. I have 12 cells in all.
Got a new (though cheapish) DMM (Extech MN36) recently and have recently runflash amp tests on these cells. All except three cells gave me readings of over 14 amps during the 1-2 seconds they were tested. Two of the 'bad' cells gave readings of around 8 amps while one cell gave me a reading of just over 3A. I recharged the cells, ran the tests again and got approximately the same results.
:thinking:
Were these cells always bad or did they degraded over time? (The previous DMM gave <6A for all cells so there's no history.)
What could I have done wrong to cause this to happen?
What exactly goes on in a cell (chemically, physically) for it's internal resistance to increase? Can something be done about it or are the cells goners?
Do these low flash amp readings also mean that the 1800mAh capacity decreased as well? (I normally measure open circuit voltages of the cells before recharging and they are all approximately the same value ie, no one cell is discharged significantly more than another.
I have a crappy feeling that they'll eventually degrade like the Sanyo HR-3 cells did.
Please help if you can.
eebowler
:thinking:
eebowler
