Underwater photography is a tricky little devil to master.
If you are "Just" doing pictures, and not video... A Flash
is your best bet to better sneak up on fish with.
A high power led light will only scare away the little
fishies. You would also cut down on gear quite a bit
if you purchased a flash instead due to less batteries
and weight. And i am sure you have enough on your
hands to deal with when it comes to taking "Just"
pictures. As far as a diffuser goes, Try an Opaque
lens cover for a scatter effect. But keep your flash
as far away from the lense as you can with a 45 degree
angle to it. My dad does underwater HD video for
PBS with a Sony Semi-pro setup. He has to sneak up
on the fishies and then turn on the leds "Just" to be
able to catch them in action if for only a few seconds.
That is where you have the advantage of a One-Time
light to illuminate your surroundings.
If you do decide to go with an led set, i can build a nice
rechargable one for you with the Warmest colors
possible. I would usually add some red leds into the mix
to offset the blue hues of the ocean. The red wavelength
does not go down to far to make things appear natural.
You may get about 20ft or so before the reds and
yellows go all muddy blue and green :mecry:.
I work with lucite/lexan on a regular basis. So its not
a problem to build you a housing with some nice
High-CRI leds in there. The Nichia brand is a quick
one i can think of.. Let me know if you are interested,
and we can talk about a proper setup for ya :candle:
Robert M.
