jeff51
Are Video Reviews of flashlights a good indicator of Pulse Wave Modulation artifacts?
I sometimes see a brief zap of PWM alien death beams in a video review.
Sometimes the reviewer mentions them. Often saying they are not bothersome.
And then followed by "Wow, look at that output, Amazing!"
I decided to take a look at the phenomena and see if I could draw some conclusions.
A little background
PWM is a commonly used method to control brightness. This is done by turning the light on and off quickly. Usually, but not always, at a fixed frequency.
Then the amount of time the light spends in the "on" part of the cycle is varied to change the brightness. This is known as the Duty Cycle.
Hopefully this takes place so fast that it is not noticeable to the user.
Video cameras control exposure by changing the aperture, ISO, and, shutter speed.
The first two are don't matter, except how changing them is related to the shutter speed.
The video frame rate is usually fixed. Typically it is 30 frames per second.
The shutter speed along with the frame rate interacting with moving objects produces visual oddities. Such as when looking at a spinning wheel, at some speeds, appears to freeze or spin backwards.
Adding the On-Off nature of a flashlight PWM into the mix can result in the camera capturing some frames where the light is on and some when it its not.
This shows up as a series of light and dark bands that move across the video frame.
"Alien Death Beams."
Some PWM controlled lights use frequencies and Duty Cycles that can be seen with naked eyeballs.
If poorly executed this can lead to eyestrain, headaches, even nausea.
So, my question is:
Is the absence of PWM artifacts in a video review a good indicator that a light has no noticeable PWM to the naked eye?
This video will look at various flashlight PWMs as they interact with the camera shutter.
The conclusion I reach is that a video review of a flashlight is not a good indicator of the presence of PWM.
Depending on the camera settings and the PWM characteristics of the light, noticeable PWM can be hidden in the video.
Conversely, a light with acceptable PWM characteristics can sometimes show PWM artifacts in a video.
PWM can be measured using a sensor and an oscilloscope.
But at what point does the PWM become noticeable, or more importantly, objectionable?
A moving object is needed to be able to detect PWM both in video and with bare eyeballs.
I will be doing some experimenting to see if I can come up with a good method of doing this sort of test.
Thanks for watching.
All the Best,
Jeff
A little background
So, my question is:
All the Best,
Jeff
