Flashlight recommendation.
ArmouredNZ
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Less than $150.
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry medium (4-7 inches).
Big enough to need its own travel caseJ.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
Other, please specify. Remote pressure switch
I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
Stainless steel (durable, but much heavier than aluminum)
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
A Red/Blue filter and a diffuser would be nice but not critical.
I will be using this flashlight for hunting so it will be mounted on a rifle. An adapter mount isnt necessary as I am an engineer so I can make one. People here have alot of good things to say about Fenix so that would be my prefered option but I am open to other brands.
Other torches I have tried for hunting with are the LED lenser P7, Surefire G3 120 lumen, Surefire scout, Cree thrower (No name brand, 230 lumens and tight beam), 32w HID with 5" reflector, and proberbly more but I cant remember them.
Out of the box I recommed the Eagletac T20C2. I believe ET makes a pressure switch, filters and diffusers. It also comes with a nice nylon holster. I had this light but never weapon mounted it, but I have a friend who does. It runs on 18650s and takes 2xCR123s. I had the R5 module which was a great thrower and got the first XML upgrade that came out and later a higher output XML drop-in came out.
I have the most experience with the Surefire G3 and the LED Lenser P7. To my eyes they seem to have about the same throw with usable hunting light out to ~75m. I would like something alot better than these. If I could get 150-200m of usable light this would be great.
How does the Eagletac throw with the different LEDs? At what range would you be able to see an animals eyes or distinguish an animal?
After some research other options I have found are:
Fenix TK21
Dereelight DBS V3
Any recommendations or opinions? I am really at a loss here as this is not my forte.
A powerhouse meant for throw, with filters and a remote switch.
I would say Thrunite Catapult V3 and Olight M3X Triton fit most, if not all, requirements.
It sounds like you know exactly what you want and or need. Have you tried the search function ? Are you currently interested in any particular light (this would help steer us in the right direction)? I'm always for helping a fellow flashaholic, but you also gotta do your own homework.
