Flashlights suffering an identity crisis
What happens when a flashlight doesn't know what it is meant for or what role it is meant to play? What if the flashlight tries to play many different roles in an attempt to find one it is best suited for? What happens when trying to be good at everything means not being very good at anything? Read on.
Part I: The Rant
These days I'm concerned with the apparent lack of thinking that goes into the design and production of some flashlights. It seems that some manufacturers want to include every conceivable feature into their new flashlight without regard to whether or not those features are appropriate for the flashlight's intended use. This is often apparent when two opposing features are present at once. A perfect example of this is a flashlight with a tailcap shroud for tailstanding ability which also claims to be good for tactical use. Never mind that a tactical user needs a protruding button! Or how about the "HA-III" claim of many cheaper lights -- what happened to using correct terminology? I feel like some manufacturers just slap a label on it, regardless of whether the light has that feature, and call it a day! It seems like they just want to make a quick buck, the buyer be damned.
There are lots of products, not just flashlights, that will either do one thing very well or they will do many things just so-so. Take automobile tires for example. All-season tires will get you around throughout the year and provide an acceptable level of traction. But if you seek the best dry traction you need summer or competition tires. If you see lots of snow, then there is really no substitute for M&S tires. My problem is not that there are some products that try to be all-in-one, it's that those all-in-one products try to claim to be GOOD at everything. There are some exceptions to this rule but they are few and expensive.
In summary, I wish manufacturers would put more thought into the intended use of their flashlight. If the light is meant for general purpose and camping, GREAT! Give it features appropriate to that end. If the light is meant for tactical use, I'd better not see a a chrome bezel and 40 decibel clicky with a shroud. If the light claims to be an EDC, make sure it comes with either a lanyard or a clip or both. These are all obvious things. Why can't some manufacturers figure them out?
On the other hand, some manufacturers are great at producing a flashlight that is purpose built. These companies produce a flashlight that doesn't try to be something it is not. The quintessential example in my mind is the Surefire 6P. It has a silent and exposed rear switch, good knurling for grip, is the right diameter, has a dead simple UI, doesn't have any chrome or shiny parts, and is the proper brightness and beam pattern. Why there are so many 6P clones that totally miss the mark is beyond me. If it ain't broke, don't fix it.
Part II: The Concept of Intended Use, Requirements, Reasonable Expectations, and Examples
Section A. The Concept of Intended Use (IU)
• Beam profile should be appropriate for the light's intended use: floody, intermediate, or thrower
• The level of friction provided by hand grip, i.e. "aggressiveness" of knurling, should be appropriate for the light's intended use
• Rear switch should only be recessed to allow tailstanding if it does not interfere with the light's intended use
• Crenelated bezel should be present only if suitable for the light's intended use
• User Interface (number and arrangement of modes, process of switching between modes) should be appropriate for the light's intended use
Section B. Flashlight REQUIREMENTS. All flashlights must meet this minimum set of requirements.
• Must have beam free of significant artifacts (I'm looking at you, incandescent Maglite)
• Must be sealed against dust, dirt, mud, water, ice, etc.
• Must have completely silent driver. No buzzing or hissing!
• Must not have visible PWM
• Must not suddenly shut off when cell(s) are depleted; there should be a period of diminishing output to alert the user to change the cell(s) (I'm looking at you, Lux III MiniMagLED)
Section C. Reasonable Expectations of Ruggedness and Quality
• Should be able to withstand shallow water submersion for at least a brief period of time
• Should have good machining, this means threads with a positive feel, knurling only where it is supposed to be, and no erroneous machine marks that interfere with ergonomics
• Should have anodizing that is consistent in color throughout with no blotches or spots missing (corners and edges)
• All laser printed text should be properly aligned
• O-rings should be lubed
• If UI provides multiple modes, switching should be intuitive and fast
Section D. Examples
Tactical: the following conditions must ALL be met:
- Exposed rear switch that is silent during activation to facilitate use with a pistol
- Exterior surface that provides friction (grip) that is not compromised if wet. This usually means knurling.
- Exterior surface that is not reflective. This usually means a dark color of flat or satin reflectivity
- Should be single mode, or if multiple modes then a UI that doesn't "get in the way"
If these conditions are not met, DON'T LABEL IT TACTICAL! I don't even want to see the word "tactical" anywhere near it!
EDC:
- accepts rechargeable cells
- multiple modes
- Rugged enough to survive drops, bangs, and some abuse
- pocket clip and/or lanyard ring
Headlamp:
-multiple modes with simple UI, preferably operable with one hand
-small and lightweight
-floody beam
Automobile/glovebox:
- LED for ruggedness
- lithium primaries for cold weather operation
- bright (~100 lm)
- 1+ hour runtime
Loaner:
- Simple on/off switch
- Cheap (if broken or borrowed indefinitely )
This thread is not meant to be another Tactical Vs. Tacticool thread, nor is it meant to pro Surefire or anti- any other brand. You may not agree with some of my ideas about what a flashlight should be. Let me know what you think!
Part I: The Rant
Section D. Examples
EDC:
- multiple modes
Headlamp:
-floody beam
- bright (~100 lm)
- 1+ hour runtime
Loaner:
