Hi,
Quick question from a newbie.
I have a couple of problem flashlights and would love to hear some feedback from everyone.
1) 3 LED pen light using 3 AA batteries and the LEDs flicker at times -- sometimes the LEDs are at half brightness, sometimes they almost go out or they do go out entirely. Shaking the flashlight a bit or changing the pressure on the cap that puts pressure on the batteries will usually fix the problem temporarily.
What's likely going on with this light? Changing the batteries doesn't seem to make a difference.
2) Reading light - incandescent bulb and a variety of AA batteries ranging from alkaline to 2700mah powerex NiMh. The light is mostly at a steady level but it occassionally will dim and then eventually brighten back up.
Again, what's going on here?
I suspect possible oxidation of the contact points on either the batteries or flashlight contacts. Am I off-base? If it is oxidation what do I do about it?
Thanks!
Thanks!
