Flydragon CSM-360 (5000-6500 Lumen)
utlgoa
Ohio
To the best of my knowledge this is the first CSM-360 LED Flashlight, and with a price of approximately $700.00(US) why not just by an HID Flashlight ?
⊙Working voltage: DC6-12V,With adapter can use AC100-240V or car adapter;
⊙LED current: :6--6.5A
⊙Power consumption:90W +/-10%
⊙Emitter:CSM360,Color Temperature:6500 - 6800K
⊙Output:5000-6500LM +/-10%
⊙Batteries:4-6 * 18650 Li-ion or 4-6 * 17650 Li-ion or 8-12 * CR123A or 2*C(26650)Li-ion or 2*D(32650)Li-ion or 6 * AA (Emergency use only)。 When using multiple Li-ion, please select high quality batteries with low internal resistance and similar discharge curves. Please ensure all batteries are fully charged before use. Note: AA batteries are for emergency use only. They cannot achieve full output.
http://www.flydragon.me/goods.php?id=41
Runtime:2D(32650)/ 6000maH * Approx. 30-40 minutes;
⊙Modes:Multi modes; multi groups; Infinitely adjustable output; Magnetic control ring.
⊙Circuit:overheat and over-discharge protection;
⊙Dimensions:Length 290 mm,Bezel diameter:82mm,Body diameter: 43mm, Tailcap diameter: 46mm
⊙Material:6061 Aluminum,HAIII (Hard Anodizing Type 3)
⊙Net weight: :1100gram
