[ QUOTE ]
PaulW said:
Arowana,
Welcome to CPF. I also have a multiple 5mm LED array light. It was my first light, and I had the same thoughts as you. I decided the thing to do was buy a focused 1 watt Luxeon light. I now think of that first light as having a flood beam, and I use it as an emergency light because it has a nice run time.
Paul
[/ QUOTE ]
Thanks for your welcome Paul. /ubbthreads/images/graemlins/smile.gif I'm exactly considering a focused beam now too. Are you happy with your focused beam light so far? I've found 2 types of focused beam lights so far, one uses the reflector to focus while the other has something like a magnifying lens on front to concentrate the beam. Which type is yours? Do you think the lights will not be so bright on those using the magnifying lens since they have to pass through extra material? /ubbthreads/images/graemlins/smile.gif Are you happy with your focused beam 1Watt light? What brand is it?
Thanks!!! /ubbthreads/images/graemlins/smile.gif
