Dances with Flashlight
2XAA SS Peak Logan XP-G R5 with Judco Switch
The Logan is built on the same head used on the older Peak McKinley. But it shares battery compartments with these Peak CR-123A based lights: the Glacier Bay, Atlantic, Caribbean, Mediterranean, and the Ranier.
The Caribbean was also available in a 2XAA format, and in Brass, HAIII, and SS. The Brass and HAIII battery compartments are produced from bar stock, but the SS is machined from SS tube. The tail end of the 2XAA SS is tapped and fitted with an adapter to hold either a keychain post or a momentary switch. Remove that adapter and you find the female threads at the tail end of the tube will also accept the Judco forward clicky switch which is standard on Peak's LEO lights.
Except for the fact it isn't brass, the Judco is a very nice switch and with a slight depression also works well as a momentary.
Note that this won't work with any of the Logan CR-123A compartments since they are too large in diameter for the Judco. It also won't work with the 2XAA battery compartments in brass or HAIII because when these are turned from bar stock they are tapped to accept only the smaller diameter keychain post / momentary assemblies, and are therefore too small in diameter for the Judco. .
