jimjones3630
I consider all these batteries used. Have taken apart packs, discharged at 0.2A and charged to capacity.
All within 10% capacity.
Emoli
IMR26700A Lithium Ion Batteries
Unlike Lithium Polymer batteries, these cells are very rugged. It is encased in a steel can similar to NiCAD/NiMH batteries.
Specs:
Dimension: 26mm diameter x 70mm length
Weight: Approximately 100g
Mfg Claimed Capacity: 2670mah
Nominal Voltage: 3.7 V
Charge Voltage: 4.2 V
Mfg's Max Continuous Discharge Rate: 20A
Max Tested Continuous Discharge Rate* 45A (15C)
* Not endorsed by Manufacturer.
Can charge with older Li-Io or Li-Po chargers.
By eliminating cobalt from the IMR26700 cell it is possible to produce a much larger cell, while providing exceptional safety characteristics. Further developments of the IMR26700 cell will provide fast charge capability, allowing cells to be fully charged in as little as 15 minutes.
Cell Type IMR26700 Manganese
Size 26.4mm diameter; 70mm length
Weight 100g
Capacity 3Ah
Standard Operating Voltage 4.2V - 2.5V
Energy Density 285Wh/l
Power Density 1500W/kg at 20 seconds
http://www.swift-tuning.com/EMOLI_26700A.pdf
A123
- Nominal capacity: 2.3Ah
- Nominal voltage 3.3v
- Charge voltage 3.6v
- Core cell weight: 70 grams
- Internal impedance: (1kHz AC) 8 mΩ typical
- Typical fast charge current: 10A to 3.6V CCCV
- 70A continuous discharge
- 120A, 10 sec pulse discharge
- Cycle life at 10C discharge, 100% DOD: over 1,000 cycles
- Power: Over 3000 W/kg and 5800 W/L
- Safety: Inherently safer and environmentally friendly
- Life: Superior calendar life, 10X cycle life vs. conventional Lithium ion
www.A123systems.com
A123 cells are POSITIVE ground casings. Uses a nanophosphate positive electrode (cathode).
Cell Specifications:
Cell Type: ANR26650-M1
Model No. AS400059-001
Nominal operating Voltage 3.3V
Dimensions: 26mm x 66.5mm ht. including tabs
Cell weight 70g
Assembly Weight 72g including tabs
- Long running constant out put, one of the flattest discharge curves of any batteries. Cells are rated 70Amp or 30C discharge continuous operation. (33C pulsed)
Emoli $15 cell
A123 $13 cell
A123 $13 cell
some bulbs, ntcs, windows, chargers on hand. Inquires welcome.
+ shipping, paypal add 4%.
__________________
Aspherical Lens for Incandescent Mods.
