Sold/Expired FS: Extreme III seconds. SOLD!
ARC mania
The land of the rising sun.
I have up for sale 3pcs of Extreme III seconds. These lights were made in low numbers. These are the last three I have left. They have a small scratch on the battery barrel which is 3mm in length and therefore considered a second. There are no problems anywhere else. Asking $80.00 shipped anywhere in the world by Express mail. If interested, send me a PM.
Specifications:
LED : Rebel LED bin number NW0D/NX0D or better.
Input voltage : 0.9V - 5.0V (AAA/10440)
AAA battery chemistry : Alkaline(1.5V), NIMH(1.2V), NICD(1.2), Primary Lithium(1.7V) & rechargeable Li-Ion 10440(4.2V)
Uses PWM at high frequency 7800Hz. No flickering from 0.2% to 100% output
AR Coated glass lens (Diameter 12mm, thickness 1mm)
HA III natural finish, no mis-match.
Single o ring seal at lens, LED module & battery tube.
3 positions twisting action for on/off and programming : off, P1, P2
Tighten for off. Reduce the chances of losing the complete head (bezel & LED module)
Lock out mode : loosen 2 turns
Stable tail stand even with small keyring, similar to the KIB flashlight.
Area lighting with white diffuser installed
water resistant
Size:
Length : 77mm
Diameter : 14mm (bezel)
ARC mania
Re: FS: Extreme III seconds. One left!
I`ll take it!
Another PM has been sent. Please confirm its availability, and I`ll then send another PP payment to you.
Thanks, Mike.
Hi Mike...
A second PP has been sent. Thank you!
I`ve also sent another PM asking for your help in setting the P1 and P2 brightness levels of the two lights at 50% and 100%. (That way I`ll have the two lights at the levels I want right out of the box, so to speak.)
Thanks again!
Re: FS: Extreme III seconds. 2pcs.
I was cleaning my house throwing out old boxes and I found three more pcs of Extreme III seconds. These are the very last two seconds that I have. If you are interested send me a PM. Thanks.
ARC mania
