The power supply is current-limited by a
Meanwell LPC-20-350 driver. The wiring is solid core 18 gauge and I think I ended up with around 200' of wire total. The project thread is located
here, but in summary I have a GFI outlet, then a timer with the Meanwell constant current driver plugged into it, then 200' of 18 gauge solid core with 10 Cree XR-Es at 350mA to serve as eave lighting around my home. If it's better to put the driver in a metal box, I can do that but I worried about heat dissipation.
I welcome any comments you may have...I love the lighting system but want to make sure it's as safe and legit as possible. SemiMan, your text was particularly helpful.
