First thanks for the help and welcome.
I have to admit MDOCOD's post was a little overwhelming, but the only way I'm gonna get this is to do it. I have some questions.
1. Why does it smell like ether when you open up a light with lithium primaries?
2. What about chargers?
3. What are the safety issues? I have seen mention of exploding cells, just how big a bang are we talking about? (My neighbor has a cat that is really annoying and I have squirrels in the attic.) The only thing I've run across is a really hot Pelican M6 when the light turned on in my pack.
I started digging around and this is what I have to work with:
1. SF G2
2. SF G3
3. Pelican M6
4. A Sportsman W'house branded light labeled 1 Watt LED
5. A multi-meter that I really have no idea how to use.
All the lights run on CR123A's. I'd like to cover the widest number of uses possible by converting the units I already own. How does my logic sound?
1. The G2 and M6 appear to close to the same light once the cells and lamps are switched out. The only difference being that one has an aluminum body the other has a plastic one. Right now, the G2 lives in a pouch that I call my "Oh Shoot Kit". It sits for long periods between uses. The Pelican lives next to my bed, it gets used fairly often. I don't really care which is next to the bed, and which stays in the pouch, but it seems that the one in the pouch should use primaries because of their shelf life.
2. The G3 should get a P-90 lamp so it can dump out more light, and have the potential to run off of primaries or rechargeables.
3. I'm not sure what could be done with the Sportsman's W'house LED, since I don't know what lamps may fit it.
Your thoughts?
Biscuits
