General Purpose Light
magua
Hello. Really enjoy & appreciate the forum. Hope you can recommend a light or two for me. Thanks.
Recommend a Flashlight Checklist:
(Don't worry about all the questions, just the ones you feel strongly about!)
Short Essay Question: What do you intend to use this light for?
Looking for a light to be used mostly for mechanical light & occasionally in the outdoors/woods. Storage life/durability are probably most important.
0) What Region/Country/State will the light be purchased in?
__X__I will be mail-ordering or buying online, so this doesn't matter.
____I am in North America. More precisely I am in _______________.
____I am in South America. More precisely I am in _______________.
____I am in Europe. More precisely I am in _______________.
____I am in the Middle East. More precisely I am in _______________.
____I am in Africa. More precisely I am in _______________.
____I am in Asia, Japan or Micronesia. More precisely I am in _______________.
____I am in Australia. More precisely I am in _______________.
1) Price Range: An easy question, but you may change your mind after answering the rest! :-)
____I only want to pay $1-10.
____I can spend $15-30.
__X__I could spend $40-60.
____I am willing to spend $80-$120.
____I have no limit!
2) Format:
_X___I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a portable spotlight.
3) Length:
____I don’t care.
____1-2 inches. (Keychain sized)
__X__2-4 inches. (Pocket carry)
__X__4-9 inches. (Holster carry)
4) Width:
_X___I don’t care.
____I prefer a long narrow light. Prefer something about an inch in diameter.
____I prefer a short wide light.
5) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
__X__I want lithium batteries. (coin cells, CR123, AAA, AA...) Storage & temp. swing durability most importent.
6) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to read a map, or find a light switch, in a dark room. (5-10 lumens)
____I want to walk around a generally paved area. (15-20 lumens)
_X___I want to walk unpaved trails. (40 lumens)
_X___I want to do Caving or Search & Rescue operations. (60+ lumens)
____I want to light an entire campground or dazzle an intruder. (100+ lumens)
7) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an “X” on the line below.
Throw (distance)------------X---------|----------------------Flood/close-up--- Adjustable focus would seem to be the most versatile.
8) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries.
____20 min. (I want the brightest light for brief periods)
__x__60-240 min. (1-2 hours)
__x__240-360 min. (4-6 hours)
____360+ min. (More than 6 hours)
9) Durability: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light.)
____Slightly Important (Walks around the neighborhood.)
__x__Very Important (Camping, Backpacking, Car Glove-box.)
____Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
8) Switch Type:
__x__I don't care.
____I want a sliding switch. (Stays on until slid back.)
__x__I want a "clickie” switch. (Stays on until pressed again.)
____I want a momentary switch. (Only stays on while held down.)
9) Switch Location:
__x__I don't care.
____I want a push or sliding switch on the body near the head.
__x__I want a push switch on the back end of the body.
____I want a rotating head switch.
____I want a rotating end-cap switch.
____I want a remote control.
10) Operational Modes: Check all that apply.
__x__A simple on-off is fine for me.
__x__I want multiple light levels. (some lights have 5-16 light levels.) ------------longer battery life/more light if needed
____I want a strobe mode. (blinks to show location.)
____I want a tactical strobe. (Flashes rapidly to disorient an opponent.)
11) Is it important whether the body is metal or plastic/composite?
__x__I don't care.-------------------------tend to favor aluminum
____I want a metal-bodied light.
____I want a plastic/composite light.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
____Red (night vision preserving) filter
____Other filter colors (Amber, Green, Blue, _________)
____Waterproof – how deep: _____________
____Non-reflective/dark finish (stealthy/hard to find)
__x__Polished silver or brightly colored finish (for easy locating)
__x__Corrosion resistant or hard-anodized finish
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Built-in second (or spare) lamp or filament
____Belt/Jacket clip
____Holster
____Wrist/Neck Lanyard
____Kobuton/self defense features
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Thanks again. Magua
You might get more responses if you narrowed the battery type and number you want. ie 1xAA or 2xAA or ?? etc.
i'm open to battery types. main thing is storage and the batteries not running down or leaking. i have a cheap light now that holds 3 aa side by side in a triangle/circle and like the shape/size of this arrangement.
Surefire G2X (2x123)
FourSevens Quark Pro or Quark Tactical (can be had in a variety of battery types)
