GITD Powder and epoxy?
LED4LYF
I want to put a GITD ring inside of my aspherical mag.
1. Where is a good place to get the GITD powder?
2. Do I need some sort of special epoxy? Or can I use just slow set two part?
3. GITD powder to epoxy ratio, how much of each?
4. Can I apply the mixture straight to my heat sink and let it set up?
Look up the glow in the dark forum (Glow Forum and yes, there really is one) tons of info there; plus, they link to the best sellers of GITD powder. (I like Glow Inc.)
the slow set clear is the stuff, should be self leveling.
No real ratio, just enough powder to get a good bright mix, just don't make it a dough. The best best is to mix it all in a heavy duty plastic bag and cut one one corner off so you can squeeze it out ala cake frosting style
Not sure on #4, but I mix and apply and then let it set, it's never failed.
I got my ultra green v10 glow powder from glow inc.
It was 9 something + shipping for a oz.
An oz. will do a good bit of mags.
I used devcon 2 ton expoxy not the 5 min one use 30 min
Used small syringe to get it on.
Sticks right where i want it to.
Mixed powder in epoxy till it was almost to the limit.
Just not dough like Darvis said.
I also rolled some thick craft paper into a tube that
fitted around the emitter to keep it from getting on anything if it was to runny.
