Glow Ring Modification
silverphoenix
I made a Glow Ring modification to my Elzetta M-60 that I wanted to share.
I went with the highest grade Glow material (Alkaline Rare Earth Metal Silicate-Aluminate Oxide Europium Doped) that can be bought (cost $35 per 1.25 OZ--this is not that cheap hobby store crap that barely holds a charge). This glow material will lose only about 5% of its glow in 10 years time and it is cheap and easy to replace if the need ever arises.
http://i408.photobucket.com/albums/pp161/silverphoenix_2008/DSCI1376.jpg
http://i408.photobucket.com/albums/pp161/silverphoenix_2008/DSCI1359.jpg
Glow Paint
http://i408.photobucket.com/albums/pp161/silverphoenix_2008/DSCI1360.jpg
http://i408.photobucket.com/albums/pp161/silverphoenix_2008/DSCI1358.jpg
When the light is in use, it charges the glow ring and when I turn it off, the bezel glows so bright that I can easily ready a map with it for about 10 minutes afterwards and I can see the ring for hours after in order to find the flashlight.
I took white nail polish and painted a ring around the bezel. I then painted the ring with the glow paint, then sprinkled the glow sand on top of the still-wet glow ring since the sand sized particles glow much more bright for much longer. I then put a clear coat of clear UV-filter-Free nail polish on top.
Let it dry for a few hours and it's ready to use!
Your images are too large and have been replaced with links
See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Norm
good idea!
I have a ring of glow tape around my 2D Mag near the tailcap, this tape is sticky as hell and has a heavy duty clear tape over it to secure it - any form of light on that and its good for hours.
Undoubtedly not as subtle or as rechargeable as your's but great idea!
