jeffsf
What do you find unusual about [the California definitions for auxiliary lighting]
Whether it is "unusual" or not, at least as I read the code, if I mount lamps at and don't run more than four "lamps" at a time (ref. 24405):
12-16"
- "Fog" lamps
- Can be run with "headlamps" (beam unspecified)
- 4" drop at 25' (which, I agree, is reasonable aiming for fog lamps to be used in conditions where backscatter is an issue; fog, rain, snow, ...)
16-24"
- "Fog" lamps
- 4" drop at 25'
- "Driving" lamps
- Upper beam only
- No explicit requirements on beam pattern in Division 12 (see further CVC 24409 on dimming of headlamps, and similar)
24-30"
- "Fog" lamps
- 4" drop at 25'
- "Driving" lamps
- Upper beam only
- "Passing" lamps
- Lower beam, upper beam permissible
30-42"
- "Driving" lamps
- Upper beam only
- "Passing" lamps
Since auxiliary lights don't bear information on them if they are "designed for supplementing the lower/upper beam" and "fog" lights don't have a definition at all in the CVC that I have found, it seems rather unclear why one would not claim that any light mounted from 24-42" above the road surface is a "passing" lamp and, hence, could be operated with either upper or lower headlamp beams, with no explicit specification on beam pattern in this Division. With my Mini's bumper/hood junction at 21.5", something like the Diode Dynamics SS3 units get me to the "call it what you want" height of 24".
Yes, I'd mount fog lamps low to reduce the impact of backscatter on visibility. Yes, in applicable conditions, it only makes sense to run them with low beams, both properly aimed.
The rest of Division 12 on mounting height and permissible combinations seems rather convoluted. Not surprising as much of it dates back to 1957, long before the US allowed greater headlamp intensity and, later, decided that sealed-beam lamps weren't the best thing going.
