Received my 5 mode MTE P7 yesterday (12060), a pair of blue 2500mah Trustfires, and the no name charger.
I really like the looks of the light, seems well made, tough, smaller than expected, and lightweight. Fits on my helmet very well. Contrary to some reports, the reflector does seem to be aluminum, not plastic, and the lens seems to be glass.
I charged up the batteries and fired it up last night. I will use it for cycling, so comparing it to my upgraded MiNewt USB (U bin P4), it's definitely brighter with a much larger light area (spill?). They seem to be about the same brightness when the P7 is on medium, but my observations were no where near scientific just firing the lights at the inside of my garage door, down the driveway, and at the fence in the backyard. It did not get noticeably warm while I was using it, but I only played with it for about 15 minutes and it was 25F outside.
The mode changes seemed a bit flaky, though. when tapping the clicky, the modes did not always change in the same order. It's supposed to be Mid/Lo/High/Strobe/SOS, but it definitely jumped all around. One time it would go from Med straight to High, and other times it would go in other orders.
I did not get to take it on a ride this morning as I ride on the road and there were snow squalls and ice on the road.
With all the modes, I'm really wishing I just had two modes: Medium (maybe about 60% of max), and high. I will never need the low or either of the strobes. And so, now for my questions to all you gurus.
I've seen another thread here at CPF that talked about removing the driver and just using the two modes built into the clicky switch, and replacing the resistors on the clicky to give me the high and medium mode. I may do that, but the EE math is a little over my head. Can someone help with the resistors I'd need to use on the clicky? Also, do I just remove the whole driver disk and wire the hot lead presently on the driver stright to the emitter? (I haven't taken it that far apart yet). Finally, are all the clicky switches the same? I.e., will the clicky that comes with this light have the ability to do the two modes and places to connect those resistors?
Thanks for all your help.
