[ QUOTE ]
Wingerr said:
Sears apparently doesn't sell knives in their stores anymore, at least not in NY.
Has anyone in the other states seen one in person?
Craftsman version
[/ QUOTE ]
Because of Wingerr's post I phoned ahead to my local Sears (Atlanta, GA) - they had 4 in stock - when I went they had the knives in red, blue and black....
and it is on sale for $6.99
The red was similar to the pale almost tending to pink red anodization of my "good" SuperKnife - the checkering makes it looks a bit darker. The anodized black was sort of translucent with a shade of blue-green when the light is held right.
Compared to the red SuperKnife -
Craftsman is a tool-less blade change - quite a clever method -
BUT the problem with this is the blade can be jiggled in the holder - since there has to be some tolerance for fitting - the movement is mostly up-down in line with the blade, but there is some side-to-side - I think the blade supplied is thinner than the one on the SuperKnife (which may be "contractor" grade) so the Craftsman
might (I'm not sure) be able to take the thicker blades, in which case this may minimize any blade movement in the holder - but this is just my
guess - if the thicker blades will fit at all.
The Superknife blade holder is solid with absolutely no play what-so-ever.
Closed - the knives are about the same length -
BUT - the Craftsman's blade protudes a lot more than the SuperKnife, making the Craftsman much wider closed.
Although the knives are comparable in thickness -
with the Superknife seeming a bit thicker -
A complaint I have heard about is the thumb-stud on the Craftsman (and Husky) -
it protrudes quite a bit beyond the scales - so the likelihood of it catching on something is quite high - not only that the tab for the blade change release also sticks out. If one tries to open the knife two-handed - (especially since one-handed opening may well be difficult for some see below) - one may well accidentally pull against the blade release tab - which opens the blade holder.....
The Craftsman feels quite bit heavier - due to its substantial - oversized backspring -
I don't think this is over-engineering - it's just to accomodate the thick blade holder.
As a consequence of this - the thumb-stud needs quite a hefty push to open the Craftsman one-handed.
It is NOT easy on my sample - this is not only due to the hefty backspring - but also a fairly sharp corner/transition from the rounded tang - in fact there appears to actually be a lip/discontinuity that makes overcoming the initial force difficult.
Look carefully at the tang end of the Craftsman one can see this "lip" - why is it there? Because it really makes opening the knife quite difficult.
Overall I much prefer the SuperKnife - at least this one (red) sample - its action and lock have a lot better feel than the Craftsman. Even though the SuperKnife requires a tool (simple hex key) to change blades this is a much more preferable trade-off for the solid no play blade-holder, in comparison to the the looser blade in the Craftsman.
