TipsyMcStagger
- Joined
- Mar 7, 2010
- Messages
- 14
I just installed six Lightolier recessed cans with magnetic transformers. I'm also installing six Lightolier trackheads with electronic transformers.
All are using a Sylvania 58309 50w MR16 GU5.3 halogen floods and are on dimmers. The Lutron dimmer for the magnetic transformers is rated for 600w. But the Lutron dimmer for the electronic transformer is only rated for 300w. I don't want to change the dimmers so I'd like to reduce the wattage of the bulbs in the track heads.
I've read that some of the GU5.3 MR16 LED bulbs flicker when used with electronic transformers.
I'm looking for recommendations for replacement LED floods with light output equivalent to 50W halogens that will not flicker with electronic transformers.
Thanks very much!
Tipsy
Thanks very much!
Tipsy
