ViReN
Re: Guiness Book - Brightest Handheld Flashlight/T
Hi All,
I Beg to differ from some of the people. From My POV (Point of View), I think for a Guiness Book Record, we should set some standadrs. A True flashlight should have following
1) Standard burntime of 1 Hour (this is a Minimum Requirement) see **** Below
2) Maximum & Minimum Lumens during that Hour
3) Total Light Output (Lumens * Hours)
4) Weighing less than 1 or 10 KG ... (see Silverster S. Note below)
There should be various Categories based on Method of Light Generation
1) Electronic (Lasers & LED)
2) Hot Filament (Most of Incand's.. including Halogens, Xenons, Kriptons... etc..)
3) Flourescence (CCFL, CFL, EL, etc...)
4) Vapour (Mercury, Sodium etc...)
5) Arc Lamps (Metal Halides etc...)
6) Other Non Conventional Methods of light Generation
There should also be catetgory for Battery Type Used
1) Miniature Battries (Button Cells, Coin Cells etc...)Alkaline, Silver Oxide, Lithium Chemistries
2) Standard Batteries (Like AAA, AA, C, D) Including Non Rechargable Lithium Sizes & Rechargables
3) Lithium Batteries (CR123, CR2) Including Rechargables; Protected & Unprotected Li-ions
4) Lead Acid SLS's etc
5) Other Non Conventional Energy Sources (Like Mini Petrol Engines etc...)
In Addition to above mentioned things, the Hand Held Flashlight should be defined as a "Self Contained Integrated unit which has a Light Source & a Power Source. Light Source may be used along with an Integrated Optics for diversion / collimating light towards a direction"
In Some Cases, like Headlamps & Some Arc Lamps, we do have a seperate power source (these should be considered seperately) & should not be clubed as in above categories.
**** ... This is because, (i am sorry Mr Bulk, I beg to differ from your statement about "true Bright" light, please dont feel offended)... A Light can be VERY VERY BRIGHT (Max Lux Reading) for just a couple of minutes... or even seconds or microseconds (in older days, that used to be the case) thats why it was called as FLASHLIGHT.. but today with advent of new technologies & other gizmossss... I think we need to redefine some things. The defination of Flashlight itself /ubbthreads/images/graemlins/smile.gif We need to device new Units for Light Measurement instead of just Lumens output. an Incand bulb.. will have 1000 Lumens .... & it throws 360 Degrees !!!... what will it be of any use ? (other than over all Area Lighting) consider same 1000 Lumens thrown at a single point (like Laser)... these things have a very specific purpose. Due to this we also need to have a category for classifying following
1) Longest Throw
2) Beam Angle & Side Spill Angle
3) Clubed with above 2 is total Lumens Output
Weight of flashlight should also be considered as parameter lets standardize it to 1 KG (maximum Limit) Everyone here is not Silverster Stalone to hold a 100 KG Flashlight in ONE hand !!!
Oh I almost forgot... there should also be a category Most Gizmotic Flashlight... like all those Menu & Configuratibility features brightness & Darkness settings... flashling & strobe settings... moon & mooner modes... automatic lockings of switches & what not /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif ....
P/G/MAG LIGHTS ARE BANNED, THEY ARE NO LONGER FLASHLIGHTS (i dont know what to call em... sorry)(Anything other than that is a Flashlight though /ubbthreads/images/graemlins/smile.gif ) ... I hope you guys understand. I am sorry folks, those who have modded P/GAGLIGHTS, Please stay away... we are talking Orignality here /ubbthreads/images/graemlins/smile.gif Other than G/PAGLIGHT... all modders are Welcome /ubbthreads/images/graemlins/smile.gif including sandwitches... bad boys.. good boys..max boys.. flexes... including n.. u .. p ... etc /ubbthreads/images/graemlins/smile.gif (ok.. thats it, my knowledge is really limited in world of modding)
Spotlights etc will not fall in this category...
Thanks & Regards,
ViReN
Hi All,
1) Longest Throw
Thanks & Regards,
ViReN
