H13/ 9008 Bulb dimensions
ccryder
Lebanon, TN
I need the dimension for a H13 bulb from the mounting surface at the back of the reflector to the filiment. I am trying to compare 9007 to a 9008/ H13. I have the number for the 9007 but can't find it for the 9008/ H13.
Thx
Neil S.
What's the object of this comparison? If you have an idea to put an H13 in place of a 9007 (or vice versa), don't bother fussing with measurements; it won't (can't) work optically, no matter what kind of physical adaptation you might do.
Also, the H13 mounting plane is NOT at the back of the reflector; the H13 seating plane is on the front of the reflector. For whatever it's worth, the LCL (light center length, distance from mounting plane to filament center) dimensions for H13 and 9007 can be had here and here respectively.
You speak in riddles (why wouldn't everything be in the correct place?) but whatevs. Glad to help.
