Please note that is a linear current regulator. So, it is VERY important to match the LED to the battery you intend to use.
Consider at 9A, dropping just 1V means 9W being dissipated as heat. Also factor in the headroom needed for it to regulate. It is possible that it can't regulate with a single li-ion and an -90 part. The latter point needs clarification from the designer.
As the designer of the driver in question, I can say that George's comments are spot on:twothumbs.
This driver was intended to fill a small part of the gap that currently exists between the availability of >5A LEDs and the lack of suitable switching regulators. When good switchers are available from George and others, I expect my design will slip silently below the waves, never to be seen again. In the meantime, orders placed by Friday are shipped on Monday.
This driver was originally intended for 4S NiMH packs and one LED, though other configurations may work well too. One user set up a single SST-90 on a 2S LiIon pack. The reg generates more heat than the LED (meaning efficiency is less than 50%), but at least he has a regulated current!
As far as the overhead required (AKA dropout voltage), it's less than 0.3V at 10A for standard 2-level models. For the mathamatically inclined, this comes from the maximum series resistance of 0.03 ohms. By changing some parts, custom single level drivers could have dropout voltages of 0.1V or less.
So yes, George, I can confirm unequivocably that a driver is available, but as you quite accurately point out, it will not meet the needs of every user, and anyone considering using it must understand the power and heat issues or risk building a light whose lifetime will be best measured in seconds instead of years:poof:.
D
