I can answer the first question. Yes, you can use standard PCB editors and generate Gerber files. The process is similar to a standard FR4 construction.
As for question 2. There are many places that will do the job and the prices vary dramatically. Local manufacturing in the states will cost your 2X-4X the cost you can get overseas. But, overseas is hard to deal with communications, time zone, shipping.
Wayne
I think you will find NRE costs in the US ranging from $750.00 to over $1500.00 + material + machine time. I had only one US quote so I'm guessing on this.
But, it seems more like high end tight tolerance FR4 PCB houses NREs start in the $750.00 range and go up from there.
Some of the precision 2 layer boards I've made requiring tight tolerances like board diameter I have paid through the nose for some stupid tight tolerances.
I once made a board that had three holes and was approximately 0.6" in diameter and had no copper on either side. I believe I ended up paying $1500.00 for 20 pieces.
Shopping around if possible will probably help scope the range of pricing.
Wayne
MCPCBs are often dubious in terms of thermal transfer anyway because there's frequently an insulator in the way - the pad for the thermal junction is often insualted from the base metal so as to maintain electrical isolation, and electrical insulation is often thermally insulative as well. What makes MCPCBs worth consideration is generally the mounting and interconnection ease, not the thermal characteristics.
I've had great success with double-sided boards whose under-device vias were filled with silver solder. (Silver conducts heat better than copper, and unloads it faster than aluminum.) I use a reflow rig to solder the LED onto the board, then flip it and use a manual iron to backfill the vias by hand. Finally I float a thin layer of silver solder over the whole contact surface and lap it flat to remove irregularities. Thermal transfer efficiency is VERY good when one uses this procedure, and can approach diect-to-heatsink mounting if you're careful in your implementation.
Where I needed electrical insulation for a filled-via board, I use a very thin piece of Kapton MT film, which is a strong electrical insulator but is thermally conductive. That combo has actually worked out better than MCPCBs for some applications.
oO
You basically "can't" solder to aluminum, either with lead-tin or lead free solder. For regular purposes aluminum is unsolderable.Will regular solder bond (proper wetting) of an LED to aluminum material. I ask, because I know the lead free solder doesn't work too well on copper, and wonder if it is even worse on aluminum.
Another question: Any ideas on how to solder an XP-G package to an aluminum heatsink without the risk of shorting the power leads to said heat sink?
Thanks in advance.
-Rick
