Has anyone experience converting a Mag Solitaire?
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
Hi guys!
I had a frustrating day and so I went flashlight shopping: 1 Relags LED keychain light, one Nordic MiniMag Clone, one Osram Dulux Mini, and a MagLite Solitaire.... and 7 white 3mm LEDs which I want to fit into it.
So after having a closer look at this really excellent CNC machined flashie I saw that it wouldn't be as easy as fitting 7 5mm LEDs in a MiniMag. The reflector is not easily removable and would be damaged when removed. So I am sitting here for a while and playing with different ideas without getting the really bright ***bing***.
Did one of you already do this? Or has anyone fitted at least one LED in there?
I am also thinking of the battery... My original intent was to use a Duracell MN21 12V batterie in there, or perhaps a stack of button cells...
Any bright ideas?
Bye,
phantomas2002
Yes, there was a discussion about that very thing a while ago....
http://www.candlepowerforums.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=3&t=000146
Flashlight Shopping? Like it
! Osram`s Dulux Mini- that`s one of my favourite flourescents- good choice!
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Phantomas2002:
Hi guys!
Any bright ideas?
phantomas2002
<HR></BLOCKQUOTE>
Also check out: "another easy 1 led conversion" (3/30/01)
I did the conversion that Chris points to. Works well. The worst part is the reflector in the Solitaire, very difficult to remove. Mine is brown, maybe a newer model, I could see no way to drill out the reflector to increase the size of the opening because the reflector "turns" in the housing. Eventually I removed the entire reflector. Slapped the LED in, put in a MN21 and a spring, hasn't left my pocket since. Great little light. Hint - Brad mentions using a small file to remove the flanges from the sides of the LED leads, I found my wife's fingernail file works just as well.
Joe
Thanks guys!
I could put in one 3mm LED easily, as I see.
But I dont get rid of the idea of getting 7 of them in there... it is still in my head... let's see if this will work in some way...
I think it would be the easy way to wait for the AAA Arclite, but I will give the 7 LED conversion a try.
