Imworking
After many attempts to make the HDS 17670 battery tube work with my Novatac EDC, I finally stumbled on the KISS (Keep It Simple Stoopid!) solution. Instead of going through all of the gyrations of taking the Novatac switch module and removing the retaining ring and screwing it on the HDC tube, this approach yielded mixed results, just take the rubber bumper from the Novatac switch and super glue it to the HDS switch module. Viola! The switch works great and strong end strikes on the light won't allow the battery to break contact and plunge the light into darkness. Someone else probably already thought of this idea but it just dawned on my pea brain. Also, does anyone know how much extra run time an 1800 maH 17670 is going to give me over a standard primary 123?
