HDS EDC programming tips?
kz1000s1
Central Arkansas, USA
I just got an HDS EDC Ultimate 60GT and while the look and feel are better than a Novatac, the UI sure isn't. With a Novatac I didn't have any trouble programming it. The HDS so far has been very frustrating, and all I'm trying to do is change light levels.
When I couldn't get what I wanted at first, I did a hard reset to start from scratch. Then I turned off force. From that point, all I want to do now is make the minimum level lower, and somehow made I changed max level instead. Also I need the secondary level a little higher. :sigh:
Thanks!
If you need a copy of the HDS instructions I may still one. Send me a PM with your e-mail if you need the instructions.
Thanks, I've got instructions. I'm just having some trouble adjusting the light levels.
EDIT:
When I finally had some more time and patience I got it the way I wanted. It's still more of a hassle
than a Novatac.
