aranwe
Hi there,
so where to begin ... i hike/backpack quite a lot so i want to replace my old flashlight, after trying friends headlamp i know i want it to be headlamp (from now on referred as HL) :tinfoil: ... but there is always a catch all the normally sold HLs are in one way or the other real compromise or too expensive (like petzl ultra / silva alpha in CZE like $450+) so i decided to create one but i need some help
Features
Buy List
LED diode
ok ... so i guess i figgured out myself that the most efficient led nowadays is cree xpg r5 ... so its the winner (if anyone has some other opinion on the most efficient led on low current - give me tip )
Reflector and Lens
Reflector will be needed i guess because i want more floody HL
Lens are needed only for throwers right ?
i was thinking on using ~52mm reflector and instead of lenses some cheap (if able to get) 52mm photo UV filter
any ideas ?
Driver
this is the most tricky part i guess ...
it must be able to run in voltage range 4.8-6V ...
i would love it to be able to run on 3AAs also ... so the range would be 3,6-6V but if it would affect efficiency i'm willing to leave it off (any ideas?)
i dont know much about led drivers so here i'm pretty much depending on your advices ...
2nd thing i would TOTALLY LOVE would be if the output could be fluently controled via potenciometer / trimmer / capacitor trimmer ...
the driver works as PWM controller right ? ... so there is some resonance circuit ? ... so by controlling size of a capacitor or rezistor could i control the size of pulse ? ... anyone already was thinking about this / already done it ? ...
THE factor in choosing the driver is efficiency and price (from what i read here on forums, there are some really great drivers but expensive ... )
if the potentiometer controlling is practicable i think that i would have to design my own driver respectively redesign some nice one (and harvest parts from some cheap driver from dealextreme/kaidomain)...
(soldering / creating PCB shouldn't be any problem)
Casing+Cooling
i have access to a 3D plastic printer for like $0.64 for 1cm^3 so i'm thinking of modeling the enclosure in autocad / solidworks and printing it ... but what i'm little bit afraid of is the heat ... i don't want it to burn a hole in my head ... though it'll be running most time on "low" mode so it'll generate little heat (right?) ... second thing i need to consider is how to make the tilting mechanism ... i was also thinking about buying some cheap HL on dealextreme/kaidomain and using it as the base .... with the place left from the batteries there wouldnt be problem to cram there any driver / jack / button / potenciometer / anything ...
Straps & rest
there wont be any problem with straps and the plastics ... cheap and easily obtainable
Thank you for any opinion on this topic ... (unfortunately i didnt find any similar project here on forums so i dont have anything to get inspired from )
BTW: if i did anything wrong, please be patient, i'm new on this forum and new to led lighting
Features
- i want it to be able both run long on batteries with low light output and if needed to shine bright as hell
- running in voltage range 4,8V-6V -4xAA batteries (to be able to run on NiMHs and alkalines)
- battery pack on cable a) attachable on the back of HL b) able to put it to pocket in winter
- price for parts - ~20-25$ - from what i see i guess i'll get a bit higher
Buy List
LED diode
Reflector and Lens
any ideas ?
Driver
Casing+Cooling
Straps & rest
