Bolster
I wear this Petzl helmet in attics and crawlspaces; saves my noggin from nails, concrete, dirt, and head bumps. Have always just slung a headlamp around it, but have been dreaming of a more secure mounting. So finally started. Was challenging to drill two holes in the helmet exactly 1" apart, and centered. (Also, this invalidates the warranty.) Glad that's done. No turning back now.
Now for cutting the mount. This was also tricky. Had to estimate the diameter of the helmet on the front part (effective diameter changes depending where on the helmet you are). Then also had to machine in a diagonal at the same time, since the helmet curves back. Here I've jury-rigged a rotary table with an extension and an auxiliary vise. The block of aluminum has been tilted to exactly 14 degrees, and the radius of the cut is 4". Slow going as the setup is not very rigid.
And here's the little b*st*rd after slotting and tapping. The slot is to lighten it a bit. It's .8 oz total. So much work for such a small piece. The outrigger holes are 1.4" apart and are for mounting a future light. Haven't decided which, or how many.
After stone-washing and a coat of clear lacquer, now mounted to the helmet. Nice tight fit, very secure. Reasonably low profile at 1/2 inch protrusion. Have run screws into the light-mount holes temporarily. The inner two holes are for the screws that mount the bracket from the inside of the helmet. Those screw heads are low profile, with washers to spread the load, and are underneath padding.
Now that I've got permanently mounted threaded holes, I need to choose a light. Am considering the H60w's that are in the mail. Don't know whether I'll mount one or two. I kinda like the idea of two, for redundancy sake. (Note that the headlamp strap mounts are back in place and still functional if I want to add a light that way, too.) What do you think, one light or two? Open to suggestions.
To be continued...
To be continued...
