jlomein
One week after getting my Surefire G2 I switched out the P60 bulb and CR123 batteries for a Lumens Factory HO-9 bulb and AW RCR123 rechargables. I found it to be very bright for its size. However, after about 60 seconds of use, I could feel the lexan lens getting very hot. Whenever I aimed the G2 at my skin from 6-12 inches away I could also feel my skin get warm after about 10 seconds.
I recently got a Cree LED drop in from kaidomain that fits perfectly and outputs a similar amount of light (slightly less, with a typical LED colour profile). When used for 60 seconds, the lens is completely cool, however the part of the G2 body where the first battery is stored begins to get warm.
I would much prefer to use the LED drop in since it is less prone to breakage and has a longer lifespan, as well as longer runtime. The heat in the G2 body causes me concern. Will this damage the batteries?
The heat generated by the incan seems to be directly forward out the front of the light, instead of inside the body. Switching to a UCL glass lens would probably fix any heat problems in the lens.
