Nothing missing, just two years of die technology.
Curt
Which strikes me a bit funny, though:
Somehow it does not compute that with the same emitter surface, an MCE should be more efficient than an R5 XP-G with lower Vf.
Something has to be missing there...
Harry is correct. The MC-E I tested was a K bin. An M-bin would undoubtedly have done better. Just going by the middle of the bin averages (400 versus 460 lumens @ 350 mA per die for K and M bins, respectively), a cooler M bin MC-E would emit 600 lumens at roughly 475 mA. Assuming a similar Vf to the MC-E I tested, input power would be about 6.0 watts, not much over the 5.8 watts required for a pair of XP-Gs to produce the same 600 lumens.
Thanks!Indeed, something is missing here. Or better to say, there is a tiny lapsus calami in jtr1962's calculation:
This claimed 5.8 wats required for a pair of XP-Gs is the wrong number. From jtr1962's own measurements http://www.candlepowerforums.com/vb/showpost.php?p=3115908&postcount=354 , two XP-Gs would yield 600 lumens at 800 mA, where the power consumption would actually be 5.1 W (2 x 2.56 W), which is the same number as I was claiming. That 5.8 W probably came from misreading the table - it would be 2.91 W per led if they were driven @ 900 mA!
Cheers.
Yep, I just relied on what you wrote being accurate without bothering to check if the numbers matched those in my lumen testing thread. :crazy: :oThis claimed 5.8 wats required for a pair of XP-Gs is the wrong number. From jtr1962's own measurements http://www.candlepowerforums.com/vb/showpost.php?p=3115908&postcount=354 , two XP-Gs would yield 600 lumens at 800 mA, where the power consumption would actually be 5.1 W (2 x 2.56 W), which is the same number as I was claiming. That 5.8 W probably came from misreading the table - it would be 2.91 W per led if they were driven @ 900 mA!
