greg_in_canada
In one thread about EverLEDs someone mentioned
the light dimming after a few minutes due to the
EverLED heating up (in a plastic flashlight I think
it was).
So I was looking at my mag and wondering if there
was a way to dissipate the heat.
The easiest I think would be an aluminum donut that
friction fits over the nut holding the bulb in, and on
the outside, friction fits against the flashlight body.
More difficult (but better) would be a donut that
is threaded on the inside that would replace the nut
that holds the bulb in. Again it would contact the
flashlight body on its outer edge.
This would involve cutting off the cam so you would
lose focusing (aside from the focusing due to threading
the head on or off a bit).
But perhaps you could leave a little bump when you cut off
the cam. Then machine a groove in the donut where the
depth varies around the circle. Basically make the
the old cam into the cam follower and the heatsink
into the new cam. It wouldn't be as smooth as the original
since it would be a sliding cam rather than a rolling
one. But perhaps with a bit of teflon grease or something
it would be fine.
The cam might have to be shallower both to reduce friction,
and so it doesn't cut through the heatsink at its deepest
point.
Has anyone done something like this?
Thanks - Greg
it was).
it would be fine.
point.
Thanks - Greg
