Help me find 2AA High CRI
Bolster
San Jacinto Mtn.
What are my options for an off-the-shelf 2AA High CRI? Tint can be anywhere between dead neutral and warm. I lego'd together a 2AA high CRI Quark with a 123 head and I love it; if no off the shelf options I'll repeat that trick.
What I would really like to find is a no-hotspot light, if possible, just a smooth even beam. However this may not be possible with all my other "wants."
From the list:
Mail order
Max $75
Flashlight
Floody no-hotspot preferred for mostly indoor use (20 yards max throw, less OK) but traditional spot/spill OK if this doesn't exist.
2AA "cigar" style
High CRI LED with tint between neutral and warm
Mass-produced off-the-shelf
Flexible on lumens, but should get >150.
Switch type - I'll adapt.
UI - I'll adapt. (Don't like flashy modes but can live with them.)
Finish - Anodized aluminum I suppose.
From the list:
Mail order
Max $75
Flashlight
2AA "cigar" style
Hey B... probably your best bet is to just do another Quark Lego. I did the same thing and it works just fine for most of my needs. (I'd rather do without the disco modes too, but, whatever.)
However, I just got a new Nailbender P60 module, my first! :D It's a special one, with a neutral HCRI XP-G2 emitter, and a low voltage driver (0.8 - 3.0 volts) so it can run on 1xAA, 2xAA, or 1xCR123. I put it in my Solarforce L2R and it's a very nice little drop-in. I compared it to one of my other lights that I know and trust the specs for (my SC60w), and the specked max (350L OTF) seems spot-on. It has three modes; Max, medium, and low. The "low" isn't a true low, however, and doesn't look like the 5% power rating it's specked at. And, the difference between medium and max doesn't look like the 30% vs 100% power rating indicated by the specs either. It's also maximum first from off, with no mode memory. Normally, I don't care for mode memory, but since it's always max first, I'd prefer the memory.
The beam profile caught me off guard too; the hotspot isn't nearly as focused as I expected. In comparison to my warm tinted HCRI XPG module from LumensFactory, it's much floodier, even though the angle of the cone looks identical to me. Perhaps that's just because it's a low voltage model so it was assumed it'd be used for more short range duties, so the hotspot is very diffuse. But, I actually like it that way, because I specifically got it to go in my L2R, so I could use it more for things like camping and hiking, as I much prefer using lights that use AAs for that.
In comparison to my SC60w on max (about 240L) the brightness difference seems right. Also, there's only a slight tint difference between them; the SC60w looks to be about 4,500K, while the new Nailbender module looks about 4,200K. The actual difference might be less than that though. My understanding is that the SC60w is supposed to have a 5A tint emitter in it, and the new Nailbender is specked as being a 5B, which seems right based on a casual visual comparison. In terms of rendering, the difference between them was subtle, but I could notice it. I definitely saw what looked like better shadow detail with the Nailbender module, and better colors from objects on the warm end in comparison to my SC60w. I'll have to do a comparison with my Jet III Pro ST, which has a neutral 5A XRE in it. The output of the Jetbeam is comparable to the Nailbender module, but the beam angle is much closer than the SC60w, so it should make for a better tint comparison. (I should probably also do another quick visual comparison between the Zebra and the JB as part of the process as well.)
Overall, hardly perfect, but a very nice little light with a very nice tint and great output. It'll work very well for me for what I intended its primary mission to be, hiking and camping. It was only $38 shipped, and it works very nicely in my L2R on a pair of Duraloops. You might have some trouble finding an L2R host though, although you might be able to pick one up on the Marketplace if you look around enough.
Goinggear has a neutral LD25 listed using an XPG.
Didn't Malkoff make a 2xAA little twisty?
ShiningBeam has the Spark and I-mini both with neutral XPG's.
It seems like I saw a Solarforce 2xAA P60 host a while back also, but I can't find it either. It must be with the Malkoff...
Barry
Hi, thanks for the replies so far.
Actually, I was looking for an off-the-shelf high CRI light, preferably without a hotspot. (Lots of rec's for neutral here, which is nice, but I want High CRI).
Foursevens has the Quark Pro QP2L available in high CRI. Maybe that with a diffuser could work?
How about the Terralux Lightstar Trucolor high-cri? batteryjunction has them for 35$ + shipping
It uses the new Cree XP-E HEW (high efficiency white) P4 led (warm and higih-cri). It does 185 lumens for 3 hours and 75 LUmens for 24 hours.
Uses 2 AA betteries. Its obviously regulated and has a "medium-flood with bright hotspot" beam.
Frankly it seems too good to be true. The only thing it's missing imho is the rubber-ring at the end, to bite on when when you need hands-free light, like the smaller, less bright Terralux Lightstar 80 form last year.
Interesting. Can't find any reviews on CPF about it, except this review on the AAA version (mixed, although post #8 may be conflating High CRI with warm).
hey bolster,
i honestly cant think of any off the shelf 2xAA lights with high CRI besides the quark. and the bin fourseven uses is rated at 85 cri. i have a few lights using the cree 90 CRI xp-g, and its nicer.
the only other option i can think of is a malkoff M31 219 or m31L 219, or M61L or M61LL 219. i have the M61 219 low, and low low drop-ins. and both work very well with 2xAA cells. because the M61 reflector is designed for the XP-G the nichia 219 beam is not as focused, and has some slight rings, but its irrelavent during use.
you can use the malkoff drop-in in a 3-cell surefire host, such as a 9P. or get a VME bezel, along with the malkoff 2xAA twisty body.
these set-ups cost a little more, but i think its worth it.
i think the best option would be to preform an emitter swap to a light that you like. someone of your profession should be able to handle it. ;)
illuminationsupply offers the 90cri XP-G as well as the nichia 219.
the type of "no-hotspot beam" youre talking about is something similar to a mule? or like a diffused beam?
Thats because it just cam eout. Why don't you do the first review? ;)
I also wrote a little review on the Lightstar 80. The color temp on mine is around 5000-5500K (in the review I say it's lower, but I'm not so sure, I find it to be rather cool) and CRI is only a little bit better then that of normal cool-white lights. For the price it's hard to beat though.
The new one should be much better...
Thats because it just cam eout. Why don't you do the first review? ;).
Tempted.
It's such an odd external shape though. Not warming up to the external machining. Does that make me shallow? :sweat:
Good mini review you wrote, by the way. You hit all the important points.
Tempted.
I actually think it looks pretty cool. It's something different and not in usual boring black. Unfortunately it lacks the bite grip...
Here I found some more pictures of the light including a picture of the front end. If it is indeed a Cree led then it must be the new XP-E HEW I mentioned above.
External color is good. It's the shape of the body...seems like they left a lot of metal on the body to get that curved surface? Heavy? Fat?
Love this photo: Going to use it in sig line!
