I've started thinking about a dedicated headlamp (instead of the Infinity Ultra in a headband).
I've narrowed my interest to these three:
Tikka Plus
Countycomm's Taktikka
Photon Fusion
Like you all, I've got my pile of general flashlights and specific-use lights, so the headlamps (would probably buy one for me and one for the wife) would be for occasional use - likely kept in the car for tire changes, brought into the home for power outage use, the occasional camping trip - not dedicated spelunking use, not daily use.
(And yes, in CPF fashion, I've considered buying both - but let's pretend I'll just buy one of them. /ubbthreads/images/graemlins/grin.gif)
In the plus column for the Tikka-size lights, I like the size and weight. For the Fusion - AA commonality, tabletop/hand use flexibility, more light levels.
All things being equal for the Petzl lights, I'd prefer the added Taktikka red filter, plus the black band is much better than that goofy print on the Tikka Plus.
So, some questions:
Tikka Plus shows 4 LEDs and three levels plus a strobe, countycomm's Taktikka show 3 LEDs, three levels and a strobe. Is there a major difference in outputs? Also, I'm seeing (on REI.com) a TakTikka Plus - with 4 LEDs (and nearly double the price). Would anyone rate the output with a fourth LED a big difference?
Also, Tikka Plus claims ratcheting head...Countycomm and REI are mum on this point for their Taktikkas. Is this correct - no Taktikka versions tilt? Is this enough of a plus to those who've used the lights to rule out or weigh heavily against the non-tilting lights?
And lithiums - can these Tikka variants use lithium AAAs?
And finally, the Fusion - is the weight/size difference enough that it's a very noticeable/major difference - does the Fusion seem bulky after prolonged use?
Especially for those who have used both, if you were going to pick one of these three as your only dedicated headlamp, which would you go with?
Thanks guys
Dave
Tikka Plus
Photon Fusion
So, some questions:
Thanks guys
Dave
