HELP MM+ lux3 vs MM+R2H
Bushman
Can any one give me an Idea how much more I would be able to gain, if any by using a MM+ with a T binned lux 3 with a 1x123 configuration as compared to a MM+ with 1w R2H? Thanks.
Please can just one person comment on this?
MM+ R2H HD VS. T binned Lux 3? I suspect that the Lux 3 will be brighter but by how much do you reckon? 20%? 30%?
I'm no expert, but here's my opinion...
I think the Lux III will be whiter for sure, but I don't know how much brighter it will be. Probably not a dramatic difference though. I have no idea what % brighter. The Lux III will be more robust though, as it's spec'd for higher current.
Peter
FWIW,
The older bin coding was more sporadic so it makes it hard to do this comparison. You could have an exception R2H or just a mediocre R2H.
The Lux3s on the other hand appear to be in a better process control and LED to LED of the same batch seem to be very consistent and comparing one type to another in the Lux3 series seem to corrolate with the actual bin code stamped.
In general, a Lux3 should be slightly brighter than a R2H. I would guess that a Lux3 S would be similar or very close to the R2H and the T would be the difference between the S and the T rank Lux3 difference.
How much is really hard to say.
Wayne
I assume that the battery life will be the same however since they are both running off the same boost circut (MM+)
[ QUOTE ]
Bushman said:I assume that the battery life will be the same however since they are both running off the same boost circut (MM+)
[/ QUOTE ]
Battery life the same.
Additional educated output guess:
The brightness difference would be almost negligible, but since the MMX+ is putting 650mA+ into the LED..-you're better off with the Lux3 becos of it's superior "luminance maintenance" ...-it's specs are in line with that 650mA, and the R2H (spec'd @350mA) is overdriven at the 650 input.
