Help:need to mod or replace two-stage clicky to one-stage
Pumaman
TN
I have a Lumapower LM-303 cr123 light I would like to upgrade. Its already nickel-plated and has a seoul installed, but he stock circuit is too conservative/ineffecient. I now would like to replace the circuit with a fenix size flupic and run it on an rcr123. this means i need to replace/mod the two-level clicky into a single level. I can live with either forward/reverse as long as its single click. If anyone knows of a drop in that might work or how to go about modifying it, the help is very much appreciated,still learning. 🙂
another option might be to just replace the circuit with another with a higher current level and just leave the clicky alone. I can take measurements, just ask whats needed. btw the driver board is 15mm., the clicky 16 mm across.
thanks
Maybe a McClicky would fit? $7.50 at the Sandwich Shoppe.
Otherwise, that looks kind of like a Nuwai Q3 clickie (old ones reverse, new ones forward, but with an interruption that ruins their Flupic operation). Or get one from a Fenix. They mount on a board like that one.
1000th post
