Help Please
DavyBoy4
Scotland
Ive Recently Ordered the New Fenix tk11 and also ordered ( ultrafire xsl 18650 2400mAh 3.7v batterys ) & The Ultrafire wf-137 Switching charger with it but got no information im still waiting on the flashlight so all i want to know is how long i charge the batterys for as they r un protected i think so i dnt wana mess things up i dont know much about them. I put a battery for a few seconds and the led on the charger was flashing red and green does it stay green when they are fully charged or what ? Thanx alot for any help any1 can give me much appreciated
Hello DavyBoy,
Welcome to CPF.
I believe your charger flashes red and green while charger and green when the charge has completed.
Tom
Yes most of the UF chargers will be green when you plug them in and then turn red when you put in a battery that needs charging. They stay mostly red while charging but about once every second or two you will see a brief green flash. This I believe is the circuit checking the voltage on the battery. When it turns steady green it is charged and is best to remove it right away. If you have a voltmeter check it to make sure your charger is not charging them over 4.2 volts. Anything much over that will shorten their life.
:welcome:
