Hi, I could use some non-flashlight related help with chasing threads, and was hoping someone here would have some experience they would be willing to share.
I need to fix some messed up threads on the end of a automotive crankshaft where a bolt holds down a belt pulley. I don't think they are messed up too bad and I'm hoping I can chase them and get them cleaned up. I did a little research and read that you should use thread chasers and not taps to do this, but I can't find chasers locally anywhere. Is this info true?
Can I get by with running a tap in there and call it a day?
Is there any advice you can give a newbie to this to help make sure I don't screw things up worse than they are now?
Thanks for any help.
