sterr11
I am trying to expand beyond using my WF-139 for charging muliple IMR 26650, both because of the awkwardness of trying to make them fit into the charger and the length of time it takes to charge. I purchased this
http://www.batteryspace.com/smartch...eablebatterypackstandardfemaletamiyaplug.aspx
on the recommendation of the batteryspace salesman, but it will not work on a single battery. It always cuts off before the cell is charged and sometimes will not charge at all after being on the charger for an hour. On further investigation of the specs of the charger, it appears to work on packs of greater than 5A. Batteryspace does not appear to be return friendly, in fact their RMA page is broken art the moment.
My question is can I rig up some way to make this charger charge multiple (3 or 4) batteries at once, which is apparently what it was designed for. Can I simply parallel 3 or 4 IMR 26650 and safely charge them, or it something else required to balance them.
If this charger is no good, what should I purchase?
