I purchased a Piglet board from goldserve in his last sale here:
http://www.candlepowerforums.com/vb/showthread.php?t=157776
I unfortunately lost (maybe deleted accidentally) all his PMs informing me how to connect it and what precautions to take.
I will be placing it into an E-Can.
Can anyone help me with the following and any other advice you can give?
1. Which wire is positive and which is negative? One is near the inductor, the other near the chip.
2. Both wires seem to go through the board and make contact with the plated ring on the bottomside. Is the plated ring battery negative (GND)? If so, how is the LED+ and LED- wires isolated from the GND? I recall goldserve saying I have to keep the LED- and GND must be kept separate.
3. If I'm supposed to solder the GND ring to the E-Can, what's the best method?
4. Any other advice is appreciated. I haven't even tested out the board (had it for a while) yet and I've forgotten everything.
Thanks.
Thanks.
