Torpedo Vegas
- Joined
- May 23, 2009
- Messages
- 44
I want to make a key chain like some I have seen here with a Titanium Weldless ring and McGizmo clips. I would like to use the 20mm Nano Clips, but can not find a Ti ring that will work. I have tried Berkly Point, with no luck, so does anyone know another place to check out? I noticed these are used in marine applications so anyone have access to them localy? I found a #10 weld ring localy that works, but I have no idea how that converts to inches. What size do I need? If they do not make a Ti ring small enough for the 20mm Nano, what size would I need for the 25mm Micro? As far as diameter I would prefer 1in, but I would consider anything up to 1-1/4 in. Any help is appreciated
